Blue smoke
Old May 20, 2009 | 10:36 AM
tr1cky's Avatar
Default Blue smoke
Hi,
Friend was driving behind me today and noticed blue smoke comming from the exhaust. It only comes under hard acceleration and I have not noticed it myself before.
What are the common causes for this? Would like to get to the bottom of it before any thing major goes wrong, or do I need start fearing the worst at 111k??
Old May 20, 2009 | 11:08 AM
Pie_n_Chips's Avatar
Oil being drawn past the control rings on the piston and getting burnt
Damaged PCV valve allowing oil to be drawn from the rocker cover/crank case and into the inlet manifold.
Pull the plugs and check for signs on oil contamination as a first stop, but all <04 engine burn/use oil to some extent, so i wouldn't worry unduly just yet.
Old May 20, 2009 | 12:04 PM
kitkat's Avatar
how much oil do you use?
Old May 20, 2009 | 01:02 PM
lower's Avatar
You weren't turning right up an incline at the time were you?
Old May 20, 2009 | 01:20 PM
Jonsey Boy!'s Avatar
And now the end is near and so I face the final curtain etc etc
Old May 20, 2009 | 01:23 PM
tr1cky's Avatar
Topped it up a couple of weeks ago, had used no more than usual.
Old May 20, 2009 | 02:16 PM
kitkat's Avatar
ok is that 1ltr every 100 miles or 1000 miles - also do you have a decat?
Old May 20, 2009 | 10:21 PM
Nick Graves's Avatar
Old person's answer!
Old May 21, 2009 | 10:59 AM
MC_BLADE's Avatar
Originally Posted by tr1cky,May 20 2009, 06:36 PM
Hi,
are you certain it was blue and not black? ....Black smoke is more likely to be overfueling.
Old May 21, 2009 | 11:06 AM
Bibbs's Avatar
Check the plugs and the seals round the plug wells on the cam cover. Mine was blue before it went pop
