Bonnet catch bolts sheared
I finally found the time to replace the bonnet catch at the weekend - or so I hoped! Didnt get very far though, as the head of the bolt sheared off as I was trying to undo it.
I don't really know how to get it the thread out now - any suggestions?? Theres not much space, and only a few mm of poking out where the bolt did start to turn before letting go.
what he said.. we used to get them out by welding on a new nut. you'd find the heat would loosen it usually
other than that you could try hitting it with a centre punch just inside the edge to tap it loose but that does often work in my experience
Thanks guys.
Problem is, theres only about 1mm of thread protruding. I cut a little slot into the end of it last night with a dremmel, hoping to then turn it with a flat screw driver, but couldn't get enough purchase/deep enough slot. I also dont have access to/don't know how to weld...
Those from screwfix got me out of a pickle once but they are shite thread off very easy plus you need to drill the studs might as well just drill them out and re tap or rivnut ( rivnut you will have to buy the tool for it but my god its handy)
Well I'll try this first. I don't have a tap and die set (or one of those rivnuts - but that looks decent!) so I'd rather try the least invasive solution first. I can also work up to drilling it out completely
