Bore Scratches
#31
Interesting stuff, and as I haven't gone this deep into an engine myself, quick question about the measurements. Is there a predetermined size of putty or similar that you put on and clamp up? Then it spreads according to the clearance (more spread = tighter clearance)? Is that how it works?
Cheers
Chris
Cheers
Chris
#32
Lower you beat me to it , bang on , and that Plastigauge is for the smallest measurements that they do.
All his his bearings are within a few .0001" and with new shells even tighter over all , hope the crank is straight and the bores/bearing housings are straight and inline as with .001" clearances there isn't much room for error ! Will it revolve nicely on a nice oil film with zero metal to metal contact in the bearings . We have discussed how we will get oil fully around the engine before first fire up ensuring there is an oil film on all bearing surfaces , he knows what he's going to do!!
Still amazed at at the condition of the crank journals and lack of wear in the shells , I bet the new shells are only a few microns smaller than the old !
#33
Cheers for that. Learning every day! I'll tuck that away for the day I rebuild mine.
#34
Toby fitted the crank today with new shells , all well within the OEM tolerances for anew engine.
we were happy with the way the crank spun with such tight clearances
#35
We also assembled the new conrods and pistons and dry fitted to big end journal to check dry clearances , again all well within OEM new build tolerances
#36
Keep it coming, still interesting! Rebuild looking good.
#40
It's not cheap , I only know cost of liners for sure , I paid for them birthday and Christmas pressie £800
i was amazed that 5 plain bearings all with around 0.001" clearance dry would spin freely with a drop of oil , with nary a sign of metal to metal contact smooth as silk . But then lots of things and I dare say moderns engines are now built to these tolerances . Lift worm gear boxes 30 years ago had to be hand scraped in , now there machine fit to microns.
More need to have a go at this as 2nd hand engines go up in price with higher mileages on , do it before bottom end failure or rod damage occurs. And who knows what happened to a 2nd hand engine in its life ! I would drop the sump and check for rubbish and look at valve retainers etc before even thinking of shelling out more than 3k of shekels. Whoops lots of puns .
toby did the right thing , loss of oil and water turn off , no obvious damage , strip down and check , all is so far fine what we have seen other than the foreign body being under the no5 main bearing shell when first assembled by Honda San ! Oh and split stem seals.
