Brake caliper unstuck
#21
FWIW are you sure it's only the piston causing the caliper to stick? I've had this before and found the slider pins to be a contributing factor also. Suggest giving them the same treatment you gave the piston to maximise the success of your work.
Hope that helps.
Hope that helps.
#22
I know some aftermarket big brake companies used aluminium pistons but i would of thought they would need to be a special grade of aluminium. Also wouldn't the aluminium conduct heat better than the stainless which will in turn put more heat in to the hydraulics which isn't a good thing for brake fade or the rubber seals. Ideally some calculations should also be done on the oem piston strength and how much thicker the aluminium one should be to withstand the high pressures. We are talking 1000's of PSI here and a failure doesn't bare thinking about.
#23
Originally Posted by surfer_crx' timestamp='1390130868' post='22972671
I think you would be better off choosing stainless steel over aluminium. There will be a reason why nobody makes aluminium pistons, and it won't be related to cost.
#24
Wildwood use stainless pistons. They aren't that heavy anyway and aluminium oxide isn't known for its friction ability.
Sliders are fine as I give them special attention and re grease ever pad change. Piston was jammed solid. All my bodyweight on a half metre bar wasn't shifting it
Hollywood Wheels
08-06-2009 01:47 AM
