Brake calliper banjo bolts
Changing brake pipes tomorrow, had quick look tonight the banjo bolts look very rusty.
The new pipes come with new washers but no bolts ,just wondered if any one new where could get them from off the shelf tomorrow if I needed to. Thanks.
Just give them a clean up with a wire brush and then stick a blob of paint on them after swapping everything over. That is assuming they arent so rusted that they round off when you try and remove them.
I also stick some marine grease on the hose fitting where it attaches to the solid brake lines, hopefully it will make it easier if i ever have to remove the brake line.
