Brake fluid
Quick question guys, I was gonna get some fluid from work but got the choice of DOT 4 or Dot 4ESP, should I spend double to get the stuff recommended for the S as it has ESP.?
ESP? extra sensory perseption does it know when you are going to brake? Bog standard DOT4 is prefect for a road going S, unless you are upgrading all the rest of the system and running it as a track car there is no point using anything else.
EPS=Electronic Stability Programme or traction control or what ever name you want to use.
Originally Posted by richmc' timestamp='1396897804' post='23101513
[quote name='martin j' timestamp='1396897413' post='23101498']
[/quote]
Brilliant! Honda specify (and recomend)DOT4 and some marketing genius invents a way to charge twice as much. I'm suprised there isn't an ABS version.
Snake oil.
My golf has an ESP button - I use it to help pick my lottery results.
I think the recommendation to use the cheap stuff to push the air out is a good idea, the ABS block can apparently be tricky to flush the bubbles from, you might want to consider this from robinette http://robrobinette.com/bleeding_the...r_cylinder.htm if you are goign to replace all the hardlines.
After that I bled the brakes once more, and they were great. And have stayed that way ever since. It must have been the trackday abuse that finally got the air out.
You can replace the fluid with a 1/2 litre bottle; I've done it lots of times.
