Brake light problem
My friend was behind me in my S2000 and remarked how my brake lights were flickering when i was braking and so when i got back to mine we had a test and got him to brake for me so i could see. It's a bit of an odd problem because when i brake sometimes it works fine and all 3 brake lights light up fine but then other times its just the lights that light up when the headlights have been turned on light up (which are pretty dim, especially in bright sunlight).
Does anyone have any ideas? i didn't think it would be a fuse because if it was then the lights would not come on at all. I'm not even sure what it could be? |
Originally Posted by Coldfuse
(Post 22528667)
dodgy earth connection
or faulty switch
Sorry i may not have explained myself. When i brake, my brake lights don't activate (my brakes work fine) but just the rear side lights come on. Does that make more sense?
How can i check the earth? |
My previous S2k, the brake light switch under the actual brake pedal failed and stopped the lights showing altogether.
You can unscrew the nut that holds it in and it pops out pretty easily, I then dismantled mine and cleaned the contacts with some contact cleaner spray and a wirebrush - put it back together and this fixed it. Worth a try as it's not difficult to do :) Just found a guide here: https://www.s2ki.com/s2000/topic/842...xed-with-pics/ |
Even more simple than that - have a look inside the wiring shroud that clips to the left boot hinge :)
Originally Posted by RichwiththeS2000
(Post 22530153)
Originally Posted by unclefester
(Post 22530158)
You're looking for a break in a wire around the hinge point i'd suspect. Just have a look at where the wire does the most bending, you may need to test continuity with a circuit tester to find the problem one.
Does your remote boot unlock button fail to work occasionally too? |
