Brakes are stuck on and no the calipers aren't seized
Find out when it arrives Jan 15th.
As long as they're not in the way of the clutch M/C or too close to the exhaust manifold, it should work...
Good job it's not an NSX - the mountings are at 45 degress, so the two are not interchangeable.
Indeed - as long as the ABS pump pipes aren't too much in the way. There's quite a boss on the M/C unions and you need a couple of cm to align the unions to thread cleanly.
Only one way to find out...
didnt realise it was boosted. that area gets much hotter than with NA, my ABS pump failed through heat i reckon, pretty low miles too..
have you tried pulling the abs pump plug off or just pulling a wheel sensor so it doesnt do anything?
I didn't scroll down the photo far enough!
Now I'm using my eyes, I note the absent heat shield.
Upshot is, maybe Notts has a point.
Perhaps John ought to invest the savings in some thermal wrap for that exhaust manifold, in order to prevent future melted master cylinder seals?
