Braking improved with pads or just placebo
Recently fitted some new front pads (yellow stuff - thanks raz) which i have just worn in following the wear in procedure.
Maybe it's a placebo but it seemed to stop a little quicker and sqid easier - i head the front tyre at say 50mph braking sharply.
However, my front pads only had 2mm left on but i never got them to fade really with my driving.
Improved or just placebo?
I use yellowstuff on my track CRX and they are significantly better than the blueprint ones I had previously been using. Not only did they seem to brake better for the same pedal pressure but they can take a lot more heat before they start to fade, even after 30 minutes on Cadwell they didn't show signs of fading.
Stop a little quicker than OEM pads? Sorry but it's obvious that aftermarket upgraded discs and pads make a world of difference.
If you are suprised by the abilities of EBC stuff then you would be literally blown away driving a car with a Dixcel set up.
Thanks surfercrx.
Dan, i've heard OEM a very good apart from fade and i dont have aftermarket discs.
I think they bite better warmed up but pads on 2mmare fooked, hadn't they started to crack and fall apart?
oem fade badly and easily ime
Improved because new and hence (a) not heat cycled umpteen times and (b) more than 2mm between the discs and the pistons, fluid etc.
The OG pads aren't bad at all in my experience. I'm not hard on brakes though and don't have a S/C!
UK Moderator
Ultimate braking is determined by your tyres, not your discs and pads. However, if your pads/discs were shagged, then you'll notice the difference.
My Dixcels bite harder for less pedal pressure, an withstand repeated abuse better than OEM, but they won't stop quicker.
So, yes, a placebo in that better braking is easier to access with better pads/discs, so it feels like you are stopping more quickly, even though you could technically achieve the same with more pedal pressure and "lesser" pads/discs.
I don't mean to sound aggresive or argumentative but lovegroova how do you come to the conclusion the car will not stop quicker?
With my dixcels I can brake later with less effort, If I were to approach the same corner with my oem equipment I would have to brake earlier to achieve the same desired entry speed, therefore the dixcels slow the car faster?
