Braking improved with pads or just placebo
#51
Failed.
In terms of "why am I on this forum", I was looking to get an S2000 a couple of years ago so signed up, but haven't really got involved since my insurance premiums are determined to keep me in an MX5 for the time being!
#52
Originally Posted by lower' timestamp='1397639548' post='23114991
Not true. Brake bias is another variable, but properly uprated brakes or pads with a higher coefficient of friction will allow you to get closer to the lock up point.
The point at which tyres lose traction is for the purposes of this discussion a fixed point, but how close you can get to the lock up point depends on how good your brakes are. The closer you can get to the lock up point the better your braking performance.
If you take the driver out of it though i.e. "in pure physics terms", there is no difference.
#53
Sorry, but that makes no sense at all. Why?
Are you suggesting you can't get to the lock point with OEM pads? If so, I see your argument, but that's simply not true. No car manufacturer sells performance cars with brakes that cannot deliver that level of force.
#54
And it's not correct to assume a better pad has a higher coefficient of friction. A good brake pad will have constant coefficient across a wide temperature range. A higher coefficient will require less pedal pressure for the same braking, but will generate more heat and possibly fade.
#55
The point i keep trying to make is that ultimate braking performance happens just before the tyre loses grip and locks. What better pads and larger discs give you is the ability to modulate the braking force more easily and therefore get closer to the lock up point and brake harder before the wheels lock.
With OEM pads the force applied by the pedal pressure and therefore piston pressure on the pads is very high at the point that the wheels lock and you don't have the ability to modulate that pressure easily. Therefore you go from using 90% (don't know the exact figures, just using the percentages for illustration) of the tyres available grip under braking to virtually instantly over 100% (when the wheel locks) and you can't modulate the brake pressure effectively in that 10%. So in effect you only actually use 90% of the available grip before the wheel suddenly locks.
Higher coefficient of friction pads require less pedal and piston pressure for the same braking effort and therefore means you can modulate the pad pressure much more easily. This means you can use more of that remaining 10% of the available grip before the wheel locks and therefore stop faster. You get the same effect by increase the disc size and therefore get more leverage or by changing the master cylinder/brake caliper piston size ratio.
DangerZone9K
01-05-2011 04:28 PM
scareyourpassenger
08-02-2010 06:32 AM
