Bush Suppliers
Just put the rear track control arm ones in, thought i would give em a punt not s/steel but with my white grease <must be used £3 a tub> went for the red the softer of the 2, got rear camber ones too do.
In the end I thought I would give it a go with these. As far as I can tell (and I certainly am no expert on this) they appear to be well made. I thought that the cross hatching on the inner bore that rotates on the shaft was quite a good idea to hold the grease that they supply. I had seen people machine spirals and grooves in the steel inner to hold the grease. They were a perfect fit in the set of suspension arms I have. I haven't fitted them to the car yet due to the weather. It's hard to work in a snorkel and mask. I accidentally bought the slightly harder ones. I didn't mean to, but the camber bush they supply (which I am not using) is the softer red material. Comparing the two, there is precious little between them. the softer is 80 Shore, the harder 90. Allegedly. I think the Powerflex purple are 80.
Anyway, now I know how, if they all fall to bits and I crash and burn, then I can easily replace them. The hardest bit is getting the old rubber bushes out. The polybushes are a doddle to fit.
DEWALT DW304PK 240 VOLT =£98.97 & 12 blades inc >>>>>brilliant
So 120 miles round trip to pick one up today <no stock near me>finished a rear camber adjuster as could not finish the cutting,other still to do.!!.<monsoon on the way> went through it like butter job Done
Grinder was a complete sh1t to use..
ps NO Ramp and on my back......
Did you not keep hitting the blades on the subframe? Using the saw?
I could not get on with the one i borrowed and wreck 5 brand new blades.
I'm trying to find out why i shouldn't use the caster bush in this set, other than not being a compliance bush, will it ruin the handling?
Hit it few times but have bi-metal blades they dont break so much,<advise Get good blades>
Front compliance,<caster>active steering correction with metalastic type <used for stability>
so will lock up more perhaps with The solid type and will loose the forgiving handling
Though would get used to it i recon
The prob is seized geo bolts, oem bushes are not available,ruining bush on removing bolts
