Clunking noise - rear near side
Hi,
well I had a rubbing grinding noise at the rear of my car for a while now, a friend replaced the rear wheel bearing for me and the noise went, however the last few days it has returned, so I would get a 'rubbing' noise ONCE per revolution of the wheel. I really don't konw where to look next. Howver today on a run out, I seem to have developed a different noise, its a very definiite clunk sound, and I can make it happen by stabbing the excelerator on and off, breaking doesn't create the noise but causing the car to jerk forward under acceleration causes this clunking sound.
So, are the two sounds related do you think? I wou8ld like to get to the bottom of this before I get to the Isle of Man in a few weeks time, so if you have any ideas please post them, many thanks.
oh and I should say there is no more heat in the nearside rear wheel than the offside
So glad you have posted about this as mine has recently developed just the same thing Nut, though I'm not sure which side at the rear it is coming from.
Its a definite 'clunk', not a 'click' like you get with a hub nut.
Mine is intermittent but like yours associated with accelerating away not braking. (I have had a wheel bearing replaced too but that was a while ago, so in my case I have no reason to suspect that the noise is related to that.)
I haven't tried to provoke it. Just off to try do that now.
I was frightened to start a thread myself as I am not very technical. Hope you don't mind me piggy-backing yours?
Hope someone can enlighten us as I am IOM bound too.
Heh heh more problems than solutions
To answer cupracing, there is no noticeable smell, and not raelly any noticeble heat, however your suggestions sound like real possibilities, I guess I need to know how to check for them, and LTB's worn cv joint?
Thanks for your help
MQ yes I hope you get yours sorted out too, I am just trying to guage a few ideas to suggest to some of my more mechanical friends what the problem might be and where to look .... good luck and let me know how you get on if you find a solution please.
I took mine out this afternoon and conditions were ideal with empty roads, everyone glued to the TV.
I can't provoke it at will however aggressively I launch but I got the 'clunk' a couple of times, always under acceleration. Mine is OSR.
I checked my wheels when I got back and all were uniformly warm and there was no smell which, I think, rules out a sticking caliper.
As you know Nut I had problems on the Dales meet. Honda have said that it was down to a faulty new spark plug. They have replaced all four and road tested the car over a considerable distance. This clunking problem obviously didn't manifest itself on the road test. Intermittent faults are a nightmare to deal with.
Hopefully we will get some pointers as to what could be wrong. I plan to take mine to my local hill-billy garage which was able to isolate the wheel bearing that I knew was failing when Honda couldn't.
Is this the common problem with the hub nut? Maybe it wasn't torqued properly after the wheel bearings were done.
I once had a clunk when pulling away on an old car. Turned out three of the wheel nuts were loose.
