Clutch.....Too light
On the topic of clutches..... How easy / difficult is it to do a clutch on the S2000?
Possible to do at home with car on axles?
Iv only ever done smaller car clutches (Punto / Glanza).
Also, what is the average life of a S2000 clutch? (normal / spirited driving)
It can be done but it's not easy (from memory Ultra_Nexus and GaryB have done them on stands but they are both nutters )
Average life depends, I've had clutches replaced on the S2k's that I've owned around the 60k mark, but there are others around that have done over 100k miles before changing.
Good times on the clutch! Car has 27K on clock, so good for many more miles!
Hmmm... if its been done before, it almost sounds like a challenge! Guess I can practice on my donor S2000 when it comes to removing the engine and gearbox. Do gearbox first and see how difficult it is!
Just a little update. Went to pump bleed the system yesterday and found the pedal had stiffened up a bit. Took her out for a good blast with plenty of gear changes. One word....Smooth!
Definitely an improvement on before. So for the sake of jacking the front up and doing a quick "gravity bleed", its well worth it!
I would suggest a pressure bleeder is better and easier - if you chose to fill the bleeder with fluid 1st. I like my bleeder bottle dry so fill up the reservoir with fluid and pressurise the bleeder so pressurised air pushes out the fluid - beware you don't go below minimum before topping up again if you use this method as air will get into the system. This method is tedious compared to filling the bleeder bottle as all you have to do with the latter method is just let the fluid bleed,maintaining constant pressurein in the bleeder.
What i like about a pressure bleeder is that even if the brake nipple threads leak then the pressure pushing the fluid out means no air can enter the system. I havent done my clutch fluid but i might give it a go soon. Sound like the OP had air inside.
