Con Rod Bearings
Con Rod Bearings
I have the rod journal code of
BBCB
and big end bore code is
3232
I have thus come to the conclusion that the bearing colours I need are as follows;
Green, yellow, brown, yellow
can anyone confirm that I’m correct with the colours I have selected?
thanks!
BBCB
3232
thanks!
if within spec re-use con rod bolts,its in the book oem spec ie,check for stretch ect..
your codes looks fine & regarding clearance ,check with plastigauge & re--check .its not a new build.
ppy1111
05-13-2016 09:33 AM
