Connecting a lightweight battery to standard connectors
Hi,
Is anyone using the standard battery connections on a lightweight small battery (kinda like a motorbike battery)?, the one i have has small plate like connectors with bolt holes through the middles and comes with bolts.
Maybe i can drill a hole in the standard ones? not keen on flattering them out as the lightweight battery might not work out as planned.
Cheers
Cheers
Cheers guys nice find - might go with these then, looks initially like you can use the stock ones and just use the existing bolt - but i havent tried yet.
As usual can't find anything that converts from a plate to terminal in the UK
Da New Yawka
06-15-2015 04:34 PM
