Corbeau Clubsports - How they have fitted in my S2000
Hi Rhauri, agree with everyone else. A thorough and useful write up. I have a question though regarding your comment on your requirements prior to buying these seats -
"Recline the seat to a comfortable level"
How can this be done with fixed seats? Is there adjustment in the rails somehow?
In terms of the lap belt fitting loosely, it actually doesn't. The side supports are not all that high, and my thighs rise above the sides by at least an inch so I still feel secure.
I am actually looking at a different seat belt clip, though; one that I could route through the side harness such as this: http://www.ebay.co.u...=item5419b11187
So if you have a look at the rails pic above, you'll see a choice of holes. At the mo I'm using the lowest hole at the rear, and the second up from bottom on the front. You could incur more recline by staying with the bottom hole at the back and using the third hole up from the front. I did initially try this and found it was a bit of a struggle to get the seat in and maintain the leg room I needed.
Hope that helps!!
Hello, Thanks for this thread, its just what I needed as I'm looking to buy the exact seat in xl. In regards to the seating position, how far off the floor is the base of the seat? It's just I'm looking to lower my seat as much as possible as I'm a lanky sod!
And I see that a company called f1 spec do extremely low side mount runners for the s2000, and was wondering if these would lower it even more. But if the base is already on the floor then I guess it would be silly for me to buy them.
Thanks again
Thanks again
Hey mate, you're welcome, was hoping it would help.
There is a little bit of room from the bottom of the floor but prob no more than 15 to 20mm! And the seats & rails do drop you by an inch.
As mentioned above I'm currently experimenting with different seat foams to reduce the sitting-height but not found the right level of firmness / height yet. I should get an overall drop of 2" I reckon.
Would be interesting to know more about those seat rails though - do they have a website?
Ah okay, so maybe the seat could be lowered that little bit more, but I do like the sound of different seat foam, that would probably be an easier way to do it.
Yes they do have a website, but I saw them on a thread on this site.
https://www.s2ki.com/s2000/topic/655...mounted-seats/
You should be able to see the lower brackets at the end of his post.
Give the chap a message he's helpful and will quote for a delivery to the UK.
Do you think the m2 rails could be re-drilled on the side mounts to get the seat sitting right on the floor to take up a that gap?
Thanks for the help
Thanks for the help
