diamond cut alloy repair Cardiff area
Old 09-04-2015, 04:29 AM
Richvow's Avatar
Default diamond cut alloy repair Cardiff area
Just purchased a set of v1 face lift wheels. they are in need refurbishing and was wondering if anyone has any recommendations in the Cardiff area?
I have been getting quotes for around £150 per-wheel to restore the diamond finish.
Was thinking about getting them powder coated instead.
Price is a concern.
Thanks
Old 09-04-2015, 04:55 AM
soulcrew's Avatar
theres a place called "love your car" on hadfield road...havnt used it, but considering sending my s2k there for a few touchups.
Old 09-04-2015, 04:58 AM
soulcrew's Avatar
forgot to add...when i went down to check them out...they had a red s2k ready to go out..it looked good.
Old 09-04-2015, 06:32 AM
richmc's Avatar
Price is a concern.
Thanks
Don't bother with diamond cut finish, it's very fragile and will last one year max before you get moisture creeping under the lacquer. And £150 a corner is fecking expensive.
Old 09-04-2015, 06:59 AM
Deleted03.15's Avatar
I had the wheels (old MR2 turbo with oem rims) done by Prestige refurbishment, they offered me the choice of either 'diamond turned with coating' or 'fine diamond turned without lacquer' and the inners painted anthracite....I went with fine diamond turning, the idea being that there is no lacquer to cause problems later on, you simply use metal polish to remove any oxidising on the surface.
Old 09-04-2015, 12:32 PM
Richvow's Avatar
cool ill check that place out and get some quotes, I've phone 2 places that were meant to be getting back to me but neither bothered?!? perhaps everyone is that busy.
Will update with some new quotes from different companies.
thanks
Old 09-07-2015, 01:27 PM
Super-reed's Avatar
I visited flat out on Penarth Rd when they started a few years ago and they couldn't do them so don't know if they've progressed. There's a diamond specialist in Brackla Ind Est that looked good but I didn't get them re-done diamond in the the end due to cost and the lacquer won't last. A mate had his turned and polishes them regular which looks good and is fine as long you enjoy cleaning :-)
typewx
09-16-2010 04:43 PM
OneQuickS2K
07-18-2001 09:25 PM
Gateway
05-28-2001 02:00 AM
qtip
05-01-2001 12:00 PM
Quick Reply: diamond cut alloy repair Cardiff area
