Diff bearings or wheel bearing?! - S2KI Honda S2000 Forums
Old 10-12-2017, 04:43 AM
Default Diff bearings or wheel bearing?!
I've noticed a slight rumble from the rear of my car that is most audible about 50mph. I've swapped rear wheels with someone else to see if it was tyre noise, but it wasn't that. Before I go about replacing both rear wheel bearings, has anyone had the bearings in the diff go? It's definitely coming from the rear.
Liam701 is offline
Old 10-12-2017, 09:55 AM
What age/mileage is your car? I've have a whin from the back of the car too. Inclined to think it's the diff, as it's not an uncommon issue.
S2000_sam is offline
Old 10-12-2017, 02:53 PM
Its done 88k miles so not low mileage and is a 2009 car. Its more of a rumbling noise than whine. I'll drop the diff fluid over the weekend and see if its clean or not. I was just after some knowledge really on if the bearings in the diff are prone to going. I'll probably replace the diff oil then the two rear wheel bearings, after all.....its only another job I'll end up doing anyway at some point! ha!
Liam701 is offline
Old 10-13-2017, 02:24 AM
Nottm_S2's Avatar
As you're driving along if you dip the clutch does the noise change at all? The diff wont be under load at that point
i had a bearing go and it was more like rubbing a wine glass around the top and noise increased with speed
the rear calipers are very prone to sticking
Nottm_S2 is online now
Old 10-15-2017, 01:17 AM
No the rumbling noise is still there. It's not the input shaft bearings on the box either. I think its a wheel bearing. I'll get to work on the diff oil this week for a start and go from there.
Do you mean your wheel bearing went on yours or a diff bearing?
Liam701 is offline
Old 10-15-2017, 01:46 AM
Nottm_S2's Avatar
The diff went on my SC car and i've had a wheel bearing fail on my other S
the wheel bearing sounded like the wine glass thing
do you rear wheels spin free?
My diff had very little debris on the plug but it doesnt even turn freely so its proper fooked
Old 10-15-2017, 09:43 AM
Winstan's Avatar
When you say you have noticed a slight rumble, is it like a vibration through the whole of the rear of the car? More apparent under heavy acceleration or higher speeds?
If So.
I wouldn't rule out the possibility of pitting in the CV cups, on the CV joints nearest the diff. Is the car on coil overs / been lowered?
If you haven't done so already since owning the car, change the diff oil, its a worth while job and a good place to start !
Winstan is offline
Old 10-16-2017, 09:33 AM
E4RTH WORM JIM's Avatar
Drive it until the component fails then you’ll know, or at least until it gets worse.
Always worked for me.
E4RTH WORM JIM is offline
Old 10-17-2017, 02:05 AM
Changed the oil and it was clean with no debris. Its not that bad but annoyingly I notice EVERYTHING! It is worse if I load the osr by doing a sharp left turn. So I think its the osr wheel bearing. Its certainly not bad enough yet to warranty replacing it. Yes the wheels spin freely, I'm pretty sure its a wheel bearing. Car is standard too. Thanks for the input anyway chaps!
Liam701 is offline
maranelloboy05
07-13-2017 04:59 AM
maranelloboy05
04-22-2017 03:11 PM
sleep
10-27-2016 10:01 PM
freakinhippie
05-19-2016 04:57 AM
Owen1290
02-19-2016 06:55 AM
Quick Reply: Diff bearings or wheel bearing?!
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
