Disconnecting the alarm
Whilst messing about trying to get my flat battery/non-starting problem solved the alarm keeps going off. Neighbours not too impressed.
I can't find any fuse listed for me to take it out of circuit - is there any way of disconnecting it - and are there any problems associated with doing this - like will it work on re-connection or will I get involved in some alarm related black arts?
just get a new car battery or take it off and fully charge it at least
afaik there is no way to disable it
to disconnect the battery you first disarm the alarm and thats it. it wont go off or work until the battey is reconnected and the alarm set (alarm will bleep when reactivated) but as the immobiliser is part of the alarm you have no choise but to reset the system
if the dash goes v dim, even completly out when cranking then the battery is flat, its enough to start the car but the heavy volt drop will trigger the alarm (i just used to leave the alarm going as it stops after 20 second rather than to retry to restart the car)
are you leaving your car for long periods at a time? this time it can be left will get shorter and shorter as the battery will not get a full charge unless you go for a very very long drive
HTH as i had the same problem
