DIY camera mount for S2k
Old 11-09-2006, 02:04 PM
Default DIY camera mount for S2k
Hi guys,
I decided to make a camera mount the other day and thought I'd share the pics with you.
What you shall need is some wood, 2 by 4 cm's will do. Some liquid metal (JB weld etc), a bolt that is long enough to go through the wood and into the underside of your camera. The next thing you shall need to make sure is that your s2k has a windblocker or furthermore some holes drilled for where a wind blocker is meant to be. The rest is pretty self explanatory... heres some pics.
Windblocker/mounting location
Windblocker removed & some tools needed
Drill 2 holes in your piece of wood that line up with the windblocker mounting points
Make sure the bolts are long enough to go through the wood and the "secret compartment" lid
This bolt needs to be the correct size for your camera, you may need to space it out with washers to enable it to fit so the camera faces the correct way
The other side of this bolt shall need to be fixed somehow. I opted to use JB weld.
Installed
Hopefully this helps someone out there for a cheap trackday camera mount. It takes a nice central shot and catches a little bit of the driver which is nice. Just be sure to upgrade your memory card for all the manic driving you shall feel like recording all of a sudden
hornyhonda is offline
Old 11-09-2006, 10:05 PM
eSeM's Avatar
Cameras have a UNC thread so you will need a UNC bolt.
(I bought a lot of these a while back if anyone needs some)
eSeM is offline
Old 11-09-2006, 11:53 PM
Installed
Don't you crash when your try and hit the picture button?
C7BLE is offline
Old 11-09-2006, 11:57 PM
eSeM's Avatar
Here is one I made earlier .......
eSeM is offline
Old 11-10-2006, 03:20 AM
that pic above puts mine to shame
Did you make that yourself?
I think the idea is to set the camera (or more so video) to go before you pull away. I was trying to think of method to take pictures via a temporary cable going from the camera to say the side of my seat, but gave up on the idea. If anyone has any suggestions on linking say some kind of mechanical switch upto a momentry switch and then a method of clamping this device to a camera it would be interesting to hear.
Old 11-10-2006, 03:27 AM
eSeM's Avatar
The mount I have was bought from a guy in the US
My Sony F828 has a remote cable that is perfect for photos/mpegs whilst on the move.
However my rear wing now gets in the way for shooting behind and my mirror gets in the way when shooting in front
I have another couple of mounts I can use.
eSeM is offline
Old 11-10-2006, 03:38 AM
Shit, thats a bloody good idea HH. Am off to Donnie tomorrow & wanted sort a mount out for then. Wish i'd seen this a few weeks ago.
Ed
echo66 is offline
Old 11-10-2006, 03:46 AM
I did something similar but with a mount similar to this:
which I just bolted through one of the holes, with the aid of one of Steven's bolts (thanks again!). Works really well!
phase_k is offline
Old 11-10-2006, 06:23 AM
Phase K - thats a nice compact unit. where did you get that from? does the camera move when you hit a bump? Im guessing that clamp holds it pretty tight.
Old 04-24-2019, 10:36 PM
Lber657's Avatar
Hi I don't suppose you have any drawings for this? Looks great to me!
Cheers Stu
Lber657 is offline
Quick Reply: DIY camera mount for S2k
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
