Dodgy idle & low rpm hesitation
#41
Replacement manifold on the way, ditto new gaskets just incase
I found the problem that had caused it to get worse - my replacement ICAV has literally fallen apart. Refitted the old one and sent a complaint to the seller and got the most broken english reply asking for photos, which I had already sent
#42
Have you checked your throttle cable to see if it is too loose or tight?
#43
Mine does it too first thing when I start it up and then get stuck immediately in stop start traffic. It Kangaroos in 1st and 2nd gear with a slight shaky idle when changing gear. Soon stops after 5 minutes or so but can return in heavy traffic again. I have cleaned out IAC valve, throttle body, map sensor whack, done plugs, done Valve Clearances, Injector cleaner and fuel system cleaner, checked VAC pipes, checked Throttle position sensors and still no joy. I am now thinking it may need one of these items replacing but cant be bothered throwing more money at it chasing a hunch. These items are either : new IAC valve, new map sensor, 1st Lamda sensor, decat it???
#44
Glad you sorted your issue rickya, must be night and day now
Mines still going annoyingly, fitted replacement manifold and although exhaust isn't blowing now its still not playing ball.
Hesitation wise it's almost like it has extreme heatsoak if it gets parked up for a moment and when its first turned on it just wants to cut out rather than idle.
Bought a low mileage used throttle body now with TPS so will see if my answer is there, fun fun fun
#46
gilstrap_s2k
10-04-2016 10:08 PM
danimal
02-22-2013 12:04 AM
andypinup
01-21-2011 12:01 PM
