Door won't unlock
Old 01-02-2011, 07:59 AM
s2000 gib's Avatar
Default Door won't unlock
Went to open the car today and as I press unlock on the fob it unlocks but quickly locks up again within a second or so. Managed to get in by the passenger side as that door will open if I'm quick enough. The handle on the inside of the driver's door is not sitting flush. Seems stuck open a little so I'm guessing this will not allow the lock knob to unlock.
I know I need to get into the inside of the door but how can I remove the door card when I can't open the driver's door at all? Anyone any ideas or would I have to just sacrifice the door card?
Happy New Year!
Old 01-02-2011, 09:49 AM
Benjamico's Avatar
You haven't mentioned what happens when you try the key?
Old 01-02-2011, 09:52 AM
loftust's Avatar
Sounds like the solenoid has packed up.
Guzzie's Avatar
Can you not try to lock and unlock it from inside first? before you damage the door card? try and have a play from inside with the lock / unlock.
Have you tried using the key and see if that would help to lock then unlock it?
Old 01-03-2011, 02:07 AM
s2000 gib's Avatar
I've tried using the key and that won't work either. Tried working on it inside the cabin and that's having no effect. I held the passenger door handle open on the inside and tried to unlock on my car and another and neither of them will allow me to open the lock if the handle is not fully depressed so I'm guessing the connecting rod is stuck somewhere and thats stopping the handle depressing fully.
Old 01-03-2011, 02:29 AM
Wobbly's Avatar
I helped a fellow member (Hi PP) who had a similar problem to you. The door solenoid on the drivers side packed in and the door wouldn't open. In the end I managed to unlock it by turning the key in the door and lifting the handle at the same time (jiggle it around a bit). A squirt of silicone spray into the lock mech helped temporarily, but a new door solenoid is probably the way forward.
Old 01-03-2011, 02:52 AM
s2konroids's Avatar
actuator
See my thread.
Old 01-03-2011, 03:24 AM
s2000 gib's Avatar
thanks guys I'll give it a try then,
Irvatron I'll try and search for your thread.
bruce0293
05-24-2013 04:37 AM
richjsy
05-14-2013 02:43 AM
Penelope Ptistop
04-14-2010 01:28 PM
DDuds2k
08-15-2007 01:46 PM
esracer
08-02-2006 05:45 AM
Quick Reply: Door won't unlock
