Are you able to run the amp in a 2 input, 4 output mode? Might just be worth doing as a test that only takes a couple of minutes.
I've just skim read the post so apologise if this has already been addressed -
Have yo routed your RCAs away from any power cables? That is usually the problem. RCAs down the centre, speaker cable one side and power on the other. HTHs Nick. |
Originally Posted by lovegroova
(Post 20379613)
I dont think so but I'll go have a check after a bacon butty. |
Originally Posted by Itchy Dick
(Post 20379636)
I've tidied up the amp install too this morning and mounted it on a piece of MDF in the spare wheel area so I have all my boot space back and managed to give the car a good wash before the rain set in. :)
not tried the rca twist idea. im using a 2ch amp and getting noise.
i've given up trying to diagnose :p spent half a week trying to get it sorted. weirdly, it only happened once i plugged in either the active cross-over or tweaters (i forget which). ofcourse, tweaters might just of highlighted the issue as it's likely to be within their frequency range. |
Originally Posted by GaryB
(Post 20378599)
Well, I spent the day chasing my tail and coming up with nothing.
Then some evening searching threw up this... http://www.audiogroupforum.com/csfor...ead.php?t=9157 Ordered a set of these, fingers crossed. http://www.google.co.uk/search?sourc...0be71e987e5a8d FIXED!!! Cable worked like a charm! |
