Hondabond
Old 10-05-2017, 07:45 AM
ValveBounce's Avatar
Default Hondabond
For various reasons alluded to on other threads, I am probably going to have to drop the lower part of the engine off to get to the thrust washers. With that in mind, please can I seek some advice concerning Hondabond.
Firstly, how strong is it? Once the bolts are removed will the lower girdle just drop off or will they need prising apart? Does it act as an adhesive or just a sealer?
Secondly, for re-assembly which Hondabond should I use? The old service manual specifically mentions a particular part number (08718-0009), but I think I'm right in saying it has been superceeded. What is the correct Hondabond to use for the timing cover, upper and lower block and the sump pan? I looked in "Under The Hood" but it looks like some of the products are different in the US. Any reference or Honda technical documents would be gratefully received.
Many thanks.
Old 10-06-2017, 08:48 AM
flanders's Avatar
Permatex Ultra Grey is an equivalent replacement, I've used it on two oil pan installs and one timing cover without any problems.
Not sure what was used from factory but the first pan removal was pretty painful and needed lots of force and prying to get off.
Old 10-06-2017, 09:11 AM
grantwestgarth's Avatar
Almost certainly need prising apart!
As for what to use, I used this on the gearbox and it's been fine... Really much of a muchness though, with any high temp engine sealant being okay, I would imagine, but I'm sure someone will come along and tell me off for saying that!
Old 10-09-2017, 07:28 AM
Liam701's Avatar
Yes it definitely will need prising apart.
Dwnfrce
03-07-2019 09:59 AM
S2k_razy
03-01-2015 02:42 PM
05TurboS2k
01-14-2008 08:12 AM
GrittyShaker
05-25-2007 11:53 AM
David1
02-14-2003 01:54 PM
Quick Reply: Hondabond
