Engine cooling fan or whatever its called.
Removed the box.
I havent a clue why???, maybe the thermostat?
BTW, i did a 150 mile trip at the weekend, the temp guage is still at the same reading as it should be, 3 bars.
cheers
cheers
Originally Posted by markS2kcU,Oct 2 2007, 11:31 AM
Didn't have the air-con switched on did you?
That makes the fans run all the time on mine if needed or not.
Originally Posted by MB,Oct 2 2007, 11:33 AM
Both the main cooling fans, Ajs?
Im not sure mark, it both are on will have a look tonight as its nice weather ATM
cheers
Originally Posted by MB,Oct 2 2007, 12:14 PM
Yep the radiator ones - is that what you mean are on all the time?
I can heard a humming noise seems to come from the left side of the engine (standing in front), i thought this sound was the fans dohhh!
Originally Posted by AquilaEagle,Oct 2 2007, 08:50 PM
The humming is the AEM - same symptom as airbox off.
Budgie stop skim reading!
It is a replacement ECU NOT an intake!
