S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   UK & Ireland S2000 Community (https://www.s2ki.com/forums/uk-ireland-s2000-community-25/)
-   -   Engine Failures (https://www.s2ki.com/forums/uk-ireland-s2000-community-25/engine-failures-806996/)
klemen123 Feb 25, 2018 11:18 AM
Originally Posted by klemen123 (Post 24340625)
Year of Engine Manufacture: 2000
Mileage on engine when it failed: 175 kilometers
Failed engine number:
Date of failure: april 2017
Symptoms of the engine: Dep rumbling/knocking/rattling when revving, vibrating trough transmission, clutch predal. Knocking/vibration coming from transmission case.
Diagnosis: Main bearings shot, spun rod bearing on cylinder 2 (probably after mains). Replaced entire block assy. with new Geniune Honda block assy. part. n. 10002-pcx-e10
Number of engines your S has had: 1
2nd. failure
Year of Engine Manufacture:2009 10002-pcx-e10
Mileage on engine when it failed:177100km
Date of failure: july 2017
Symptoms of the engine: while accelerating engine developed a vibration/knock similar to previous failure. similar simptoms.
Diagnosis: sent entire car to honda dealership and waiting for results.
Number of engines your S has had: 2
Honda gave me a new engine! im happy with that. Cause for the new engine to fail after just 2000km?..well rust on main bearings. Bearings just fell appart after a few heat cylcles. No contamination in oil (water, coolant,...).
© 2026 MH Sub I, LLC dba Internet Brands
