Enlarging wheel centre bore for S2000
Originally Posted by r8byb,Feb 21 2011, 07:06 PM
9j front 10j rear - 235 - 245/40 front, 255 - 265/40 rear
Originally Posted by exalto,Feb 21 2011, 06:20 PM
I think m1bjr looked into this when he wanted to put OEM rears on the front for non staggered set up.
I used oem 2007 rears on the front for non-stagger. Fantastic mod.
Local car engine refurbishers turned mine out to a clearance fit for £40.
Anyone with a big drill can do it.
BUT make sure you explain about centre caps if you have them.
Maybe you wont want to go the full depth.
Steve
could do it yourself depending on how much material you need to take away
if its a small amount get a dremel or die grinder and be gentle untill you remove enough material then take the wheels to be ballanced and everything should be ok.
its a brave move to do on a set of BBS rims
Uncle Fester
02-27-2004 09:44 PM
Scot
08-29-2003 06:50 AM
