Exhaust/Manifold...
#51
That's entirely upto you but, as Earls says, people on here are completely paranoid and if you don't put an OEM Honda oil filter on with Castrol edge, your car will immediately blow up.
Is an ECU going to be beneficial for running an Exhaust manifold, exhaust system, and air intake? Of course, but if you ask the tuner they will be removing the fuel, making it run leaner to up the power.
I have no problem with opinions either, but if it's stuff that affects people's practical decisions, I'll speak up about it if it's wrong.
#52
UK Moderator
FWIW you are both right.
Some combinations of these items will cause an AFR problem - kim-s2k had a problem with the DMS parts he fitted, so much so that at the dyno day a couple of years back, his runs were abandoned.
On the other hand, earl's figures are pretty good.
#53
#55
Originally Posted by Mish' timestamp='1441018689' post='23731958
thanks all, interesting options...
Thanks Greenman,
Really looking for improved sound, more of a performance 'note'... without being ridiculously loud or 'droney'... want to stay within UK legal sound levels whatever that is.
Not sure I'd go with a manifold as well at the moment, possibly a decent cat back system will suffice... although interested to hear if anyone has fitted a performance high flow cat and if its helped at all.
Would prefer to maintain a dual exit (rather than go for some of the single sided exits).
What companies have people used?
On the tuning... is a remap necessary if going for a manifold too? If so, what tuning places are people going to to have this work done?
Cheers,
Mish
Thanks Greenman,
Cheers,
Mish
I could be wrong but the standard ecu isn't map able, you have 2 options get a js racing/spoon ecu or go hondata/aem if you want mapping.
Think must people run decats Tbf.
Hope that helps
I have a Mugen exhaust, because I wanted something that sounded better, saved weight, aids performance and doesn't drone. I also fitted a Tracy Sports TS-02 manifold, which was fitted at the same time to save a little on labour. I'm still running the stock CAT, but a Berk HFC will be next, since they're good value in terms of bhp/£.
Given a new car, I'd do the same again, but install an HFC at the same time as the exhaust and manifold.
I added a Mugen intake soon after, which is nice and quiet and makes a modest difference, but I'm still lusting after the PWJDM. I'm saving up for a new ECU, but plenty have run aftermarket I/H/E without issues, so I'd do it for more mid range rather than concerns about safety.
#56
I think most cars will run lean somewhere in the rpm range when you ad a few good breathing mods.
Probably not enough to cause the motor to blow but maybe cause some extra wear though.
On my '03 with intake, manifold and exhaust mods I had to ad ~10% more duty cycle around 6-7000rpm to get the AFR down to ~13.
GaryB
10-24-2012 09:53 AM
GaryB
01-23-2012 05:50 AM
RichwiththeS2000
07-29-2011 01:59 AM
