Expansion bottle screw cap - heads up.
Quite - which is the reason i only ordered the screw on bit and reused the rest of the old one. As i said, i only noticed it was broken because i'd noticed a slight loss of coolant in the tank ( i do keep an eye on this stuff) - just glad it's a piece of broken plastic and not a leak somewhere more expensive.
The tank sees pressure simply by the fact that it is a pressure relief mechanism for the coolant system. If old enough, it can fail due to heat cycles and the pressure; I have had one rupture in this fashion and the coolant all over my engine bay at the time could attest to the pressure the tank was seeing.
Originally Posted by miloking
get rid of the plastic one... i bought this few years ago for around that price and couldnt be happier
i will look thru my old emails and try to find it for you...
EDIT: got it from Moddiction ...together with convex blue mirrors...
I've seen the Moddiciton one but only combined with a catch can, pretty pricey as well.
I think this is the source Schmuck Built LLC – Performance Automotive Fabrication and Design
They seem to have a round version now though.
