Failed MOT today
Failed MOT today
Hi everyone,
My S2000 failed its MOT today on the following:
1. Rear brake application uneven
2. Rear brake release unevenly
Doing a search make me think its the calipers. Could this caused by the calipers starting to seize?
I've noticed that the discs have a ring of rust on the outer edge where the pad is obviously not making good contact with the disc. They arent seized on as the wheels arent getting warm.
Its going back tomorrow for them to try and fix the problem. They will start with swapping the pads for some new ones. Hopefully winding the pistons back might free them up.
Anything I can have the garage do to try and free them rather than just new calipers?
The car hasnt been used much recently, so I'm not sure if this has contributed.
Thanks
Alan
Thanks
Alan
I'm surprised they could tell - I hope they didn't use the brake test rollers on a car with an LSD.
Always worth telling them that they have to test it on the road not on the rollers which can damage the LSD.
Probably should put that MOT rule in the FAQ's somewhere?
didn't know that Si
they might sieze not on but normally you would see heat on one or both wheels as the brakes would not be completely siezed and would 'drag' after they'd been applied.
a decent mech will be able to free them up and clean them unless they've rusted (mine never have)
Thanks!
They probably got the right results to be honest, but they shouldn't be testing it on the machine.
Having watched them trying to test on the road, it is much less accurate, especially on identifying the differences between wheels and they would probably have missed this kind of problem.
see vehicles not to be tested on a roller brake tester in the link below..
"Certain vehicles should not be tested on a roller brake tester, eg vehicles with More than one driving axle permanently engaged Limited-slip differential Belt-driven transmission"
http://www.ukmot.com/3-7.asp#Text_top
When testing brake efficiency on cars not to be put on the rollers it's not possible to see which wheel is sticking, it's only the deceleration rate that gives a reading on the machine. If when on the ramps the wheels were spun by hand the tester should have been able to seee/feel a difference side to side.
To be honest when mine was done at work(Honda Dealer) I don't know if it was done on the rollers or out on the road, I'll need to check, banned from the workshops while it was done in case I threatened/bribed the tester.
