Fast Road Set Up
Old 04-17-2014, 01:09 AM
bruceski's Avatar
Originally Posted by Dembo
Originally Posted by bruceski' timestamp='1397723568' post='23116838
Possibly should have elaborated a little. Basically a 4-wheel alignment, to adjust camber,caster,toe etc.
You should definitely do that.
Just wondering if it is worthwhile after installing coilovers or should i just stick with OEM settings?
What do you want from it? If you wanted OEM, you probably shouldn't have fitted coilovers. It's certainly worthwhile, makes a huge difference, but a more aggressive setup probably means more tyre wear and more unpleasant tramlining.
Ok, your point is noted next time be more specific with question.
thanks
Old 04-17-2014, 01:25 AM
razzele's Avatar
Revolution staff have a lot of tyre pressure on them, if they can't align your car in the slot allocated they will just leave it.
Old 04-17-2014, 01:37 AM
Nottm_S2's Avatar
You lot are f@#king pedants, you have a broad idea of what he means, ie should I have less 'lowest common denominator' settings on my car
Yes is probably the answer.
Not being an expert I guess take it to an expert and tell him what you want. Stuff like high speed stability (this was an issue with mine last time I did it), steering feel, less snap oversteer etc etc
Old 04-17-2014, 01:48 AM
bruceski's Avatar
Ok thanks, so are they any good? anywhere else you could recommend?
Old 04-17-2014, 02:14 AM
tozerman's Avatar
Old 04-17-2014, 02:18 AM
markforrester99's Avatar
Dont worry too much about tyre wear.
Aslong as they dont go mad with the rear toe then you can get good tyre wear. I run -1.3 camber at the front and about -2 at the the rear. I have total toe in of 0.15 on the rear and the car is stable and isnt eating the tyres.
Old 04-17-2014, 03:14 AM
Krisbuc's Avatar
Had my 2000 aligned by revolution and they did a very good accurate job drove much better after but all wheels were out a bit
Old 04-17-2014, 04:14 AM
bruceski's Avatar
Good! that is where I will probably end up going. Unless anyone can suggest anywhere better
Old 04-17-2014, 04:18 AM
bruceski's Avatar
Upon recommendation from several other members (see this thread: https://www.s2ki.com/s2000/topic/865498-geo-settings/ and https://www.s2ki.com/s2000/topic/872...st-road-setup/) I would probably go for something like this:
Front camber 1[sup]0[/sup]
Front Toe 0[sup]0[/sup]
Caster 6[sup]0[/sup]
Rear camber 1.5[sup]0[/sup]
Rear toe 0.5[sup]0[/sup]
However I am open to suggestions
Old 04-17-2014, 04:33 AM
nomadicS2k's Avatar
They look ok - As recommended, take these settings and tell revolution what you are looking for and they will work it out from there.
Quick Reply: Fast Road Set Up
