Fitting the roof cover - with roof tube
Originally posted by bmarshall
Thanks for responding Muz. I'm not trying to damage you're products or reputation here, but my cover really won't fit with the tube in. I can also see about ..
Oh... and make sure your Roof Well Mat is not sitting over the indentations that the rook mechanism folds down into.
Originally posted by awinskill
Muz - my roof mat covers the indentations...... Have I buggered that install up too
The Velcro tabs are to ensure it does not move and obstruct the indentations.
Originally posted by Muz
Hey no problem at all Perhaps try untucking the outer cover and trimming the tube down a bit. I make sure mine is about the length of my roof well mat but it could probably be shorter... as long as it covers the width of the window. Don't go too short though.
I can take the mat out and try, but the mat doesn't appear to interfere at all.
The roof tube is pretty long and could probably lose an inch or so, but that kind of defeats why I paid for one, rather than making one. I don't have sewing equipment so I can't tidy up afterwards...
-Brian.
Err? My roof mat's too big to fit between the indentations. It just goes to the edge of each raised bit so it's perhaps 2 inches too wide.
-Brian.
-Brian.
An 'indentation' is a recess _not_ a raised area. The mat is the correct length.
Re: the Window Tube
You can untuck the outer covering from one end of the tube, trim the tube and tuck the covering back in. They were designed like this intentionally and no skill is required to do it.
The raised areas seemed to be the obvious "shutline" for the mats. I'll double check in the morning.
Thanks for the clarification!
Re: the Roof Well Mat
Re: the Window Tube
Re: the Window Tube
The mat thing seems to be a little confusion with the instructions. My instructions were clear on it in the indentation between the little raised bits. The mat actually sits on top of the 2 raised pieces. If the mat is supposed to fully fit in the indentation it is too long.
To clear this up fully have you got a photo of how your own mat sits in the well at the sides? I think that would be a lot clearer than interpretations of text which seems to be causing a little confusion.
-Brian.
Originally posted by AnDy_PaNdY
My mat sits on top of the two raised pieces also.
Seems to work fine and I have no problem with it at all.
My problem is:
mat+tube+cover == doesn't fit.
mat+cover == fits perfectly.
I've measure the roof as per TSB-38, and it's within spec. I still have to shorten the roof tube and try that.
-Brian.
