Floor jack
Old 03-01-2019, 04:56 AM
Brailer's Avatar
Default Floor jack
Looking for a recommendation for a floor jack that can reach to lift the car from the front as well as the back please.
Cheers
John
Old 03-01-2019, 05:06 AM
chrispayze's Avatar
You'll struggle if lowered at all (and it's very close even without). But I've got a pair of small plastic ramps (machine mart) plus the low profile steel red jack (also machine mart). Good combo.
Old 03-01-2019, 05:25 AM
Brailer's Avatar
Got a model number of the jack please? Just had a look and didn't expect to see them at £100+
U can also get them cheaper but don't know what's suitable.
Old 03-01-2019, 08:01 AM
Chuck S's Avatar
Received 1,128 Likes on 991 Posts
You'll probably need the car just a bit higher to get even a low jack underneath. I need these for my stock height car. Nothing more than 6 feet of scrap wood shelving cut into 2' and 1' sections and nailed together with flat top roofing nails.
-- Chuck
Old 03-01-2019, 09:00 AM
Daytona-Dave's Avatar
http://www.sgs-engineering.com/
Old 03-01-2019, 12:33 PM
Soggybottomboy's Avatar
I have one of these
https://www.sgs-engineering.com/tj3l...e-trolley-jack
It needs the front lifted slightly to reach the central jacking point but has no issues with the diff jacking point.
Car is stock height.
Old 03-01-2019, 03:27 PM
BenRNBP's Avatar
What those two said ^ although I have the 1.5T one https://www.sgs-engineering.com/tja1...m-trolley-jack - it can just bite and lift from the front centre jacking point but easier to roll on to a plank of wood on one side to get it going
Old 03-01-2019, 10:48 PM
Boldys2k's Avatar
https://www.machinemart.co.uk/p/clarke-ctj2qlp-2-tonne-quick-lift-low-profile/
This just about get from and rear of mine. It's lowered about 25mm.
Old 03-01-2019, 11:16 PM
Brailer's Avatar
Thanks guys. All these jack's are £100+. Do I need to spend that much?. Will work out cheaper to get work done at garages.
Old 03-01-2019, 11:48 PM
TangoVTEC's Avatar
Well you do get what you pay for, and given the criticality of the jack’s duty (you might be laying underneath the car for instance) it’s not an item I’d want to scrimp on.
It is one of those garage tools that pays for itself many times over. I paid £200-something for mine nearly 8 years ago, and with light maintenance it has always been dependable.
Make sure you have some decent axle stands and with those and the jack you can get lots done on your car yourself.
If I added up the amount I’ve spent on tools over the years I’d probably pass out, but each one has been a lifesaver at some point (many almost every time I work on the car) so it’s money well spent
Quick Reply: Floor jack
