S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   UK & Ireland S2000 Community (https://www.s2ki.com/forums/uk-ireland-s2000-community-25/)
-   -   Found fault code (https://www.s2ki.com/forums/uk-ireland-s2000-community-25/found-fault-code-768239/)
barefoot Feb 23, 2010 08:15 AM
Found fault code
Got my code reader today one fault code shows as 0132 and is as below in the tech section:
P0132 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Circuit High Voltage
I have just bought a primary Lambda sensor and will fit it tomorrow am I correct in thinking that is what this code/fault is and should this clear it?
Kev
mdjohnso Feb 23, 2010 08:50 AM
mine was P2A00 (although I don't think that's a valid code? but it's what's on the invoice)
P2A00 Air/Fuel Sensor R
MB Feb 23, 2010 10:03 PM
Yep, Kev, that should sort it.
Your MPG should improve too.
barefoot Feb 24, 2010 12:43 AM
Fitting it this aft MB will let ya know ta.
s2konroids Feb 24, 2010 01:40 AM
Spot on, Told you it was your lambda sensor ;), if it acts funny again it's because the new ones response rate doesn't suit the car.
barefoot Feb 24, 2010 06:42 AM
Changed sensor thank god for my brother's ramp would have been no fun on axle stands. Drove off car was immediately missing for 20 secs then cleared as normal. Did an ECU reset and have driven it all day stopping and starting etc and it's been perfect thanks for the help/advice!
MB Feb 24, 2010 10:18 AM
No probs.
The sensor is easy, but that bloody connector.... :banghead:
© 2026 MH Sub I, LLC dba Internet Brands
