Fuel Pump
Sorry for starting another strange noise thread..... ;)
After I pull up and turn the engine off I can hear what sounds to be the fuel pump turning on for about 1 second waiting about 5 and then cycling again...... Gets a bit like Chinese Water Torture... Is this normal or am I turning into a real anal muppet? ;) After taking Brian's advice I don't really want to talk to my dealer again. :rolleyes: |
Originally posted by awinskill Sorry for starting another strange noise thread..... ;) After I pull up and turn the engine off I can hear what sounds to be the fuel pump turning on for about 1 second waiting about 5 and then cycling again...... Gets a bit like Chinese Water Torture... Is this normal or am I turning into a real anal muppet? ;) After taking Brian's advice I don't really want to talk to my dealer again. :rolleyes: - Yes, you are turning into anal muppet. :p You should be used to all sorts of weasy noises owning an Impreza! :p - Put you're bobble hat on, then the dealer you show you proper respect ;) I didn't notice anything particular when I pulled in this morning. Though I did raise the roof when I stopped. -Brian. |
If the engine is off I don't think it will be the fuel pump, maybe the evaporation canister sucking out crankcase fumes?
Could be your anorak and sandwiches moving around in the boot:eek: ;) :p
Originally posted by AnDy_PaNdY Could be your anorak and sandwiches moving around in the boot:eek: ;) :p Snadwiches were in my belly so no worries there... :D |
I heard that noise once - after a quick drive back from Devon at night. I gave up trying to trace it, but it wasn't from under the bonnet, more the middle of the car on the passenger side. Anyone know what's hidden under there ? Another secret compart
ment ? Steve |
Originally posted by steve_the_greek I heard that noise once - after a quick drive back from Devon at night. I gave up trying to trace it, but it wasn't from under the bonnet, more the middle of the car on the passenger side. Anyone know what's hidden under there ? Another secret compart ment ? Steve |
Andy,
miine does the same, when I put it in the garage you can hear a whirling noise, then it stops and then off it goes again along with all the popping from the CAT. I often wandered what it was but it never overly concerned me I just thought it would be something cooling down. BTW, anyone else noticed just how long our engine stays hot, I can leave my car in the garage for two hours go in there and its warm as toast, if I then restart it, I've still usually got 2 or 3 bars on the temp gauge. Good jobs its garaged or all the neighbours cats would be camping out on it during the winter:( |
At the risk of being admitted to the anal anorak club (AAC? - sound like an African political organisation), there was thread on this a few months ago, and a few theories about what causes it (my car 'moans' every minute or so when at rest! :confused: )
Go here if you must: https://www.s2ki.com/forums/showthread.php?...hlight=fog+horn Ian |
I don't know about turning off but if you listen very carefully when turning the key (before starting the car) you will hear the short whirring sound of a pump, presumably fuel. Perhaps it's the same noise?
