gauges, oil temp, water temp, rev.. ?
Hi guys, im wanting to tart up my cabin and make it look more pleasant at night..love gauges etc.. im wanting to get an oil temp, water temp and maybe a rev meter...purely cosmetic..has anyone come across a thread on how to wre them up..im sure some of the wires will need to go into the ecu etc? if anyone can help.. it would be greatly appreciated. Thanks ppl!
With regards to powering the gauges if you search for "hardwiring' you will see a convenient source for power ( i think its in the FAQ as well)
You can buy inline adaptors for each of the sensors. You may require a sandwich plate with appropriate takeoff ports for and oil temp/pressure sensor. Merlin motorsport are very helpful on the phone and have a good website for these fittings, though id say they are pretty expensive.
Water temp you will need to cut the rad hose and splice an adapter in, sandwich plate between oil filter and engine for the oil temp and pressure, oil pressure alone can be taken from the same spot as the OEM oil sensor
Why a rev counter there's a big one on the dash?
ericmdub92
05-20-2018 10:13 AM
johninator
04-22-2011 12:45 PM
Russ
09-04-2002 12:40 PM
