Geo adjustment
If you just want the Honda settings putting on then go down your local place that has a Hunter machine and it shouldn't cost you more than £70.
If you want a custom job, then the companies you mention would be a good start, although I have no idea on price nowadays, although I'd expect WIM and DMS to be cheaper than CG.
UK Moderator
WiM prices here http://www.s2kuk.com/s2kuk/Benefits/...ers.php?cat=15
DMS prices here https://www.s2ki.com/s2000/topic/831...t__p__19868278
CG is a lot more.
CG is a lot more.
My local Hunter guy works like that, £20 to check it over the charges per adjustment so if an ajustment isn't needed it's not charged. So may not be as much as £150+.
cambridge performance tyres are the same, 150 quid plus vat although you can talk them down very quickly. And the guy there Stuart knows his stuff. They will charge you 20 quid just to check it and tell you and show you exactly what needs doing.
Where are you based?
