Geometry Discussion...
Well I thought it would be useful to have a geometry discussion thread, where you can post a pic of your geometry print outs, car ride height and discuss it.
So to start here is mine, opinions? Is there anything I should look to change? My front near side caster adjuster was seized, all others were free.
No banter please, this could be an informative thread.
I'll get mine scanned when possible and post after the hols, no scanner at home.
Banned
What would you like to know?
my settings are
-3.1 camber R -2.3 camber F
+1.5mm toe R 0 toe F
standard castor.
Car feels great to drive really sure footed compared to standard, it hasn't had any adverse effect on tramlining which I thought it may do. I really have no negatives the rear feels planted, the front doesn't understeer, what more could you want
Also just to add, I've had the same tyres with these settings for 7000 miles and tyre wear is perfectly even on all four corners!
my settings are
standard castor.
UK Moderator
Here is my geo history (up to a point, although things are reasonably settled now with some slight changes. It's certainly interesting to see how much it gets knocked out of whack over the course of a year.
1 deg camber at the front, 6 deg castor, 0 toe
2 deg camber at the rear, 30' toe each side
I'll be the first to admit I don't know how it actually affects the car, just know what camber, tow, and caster etc. means and when it wad don'e properly the car drove 100% better.
Banned
Toe points the wheels in or out in relational to horizontal line down the centre of the car. Toe out will generally make the rear feel more loose but more responsive, toe in will make the car feel more stable but less responsive. Different chassis's and suspension layouts react differently, although that's the general rule of thumb reguarding toe.
Camber is really down to personal preference and really what your aiming for is creating a perfectly flat tyre when cornering. If your running road tyres you may be able to create enough roll to bring the tyre flat in a corner with -2.5 camber before the grip levels go off. Running semi slicks you may be able to run -3.5 as the tyres generate more grip creating more roll to bring the tyre flat when cornering.
Hope that helps
Hope that helps
