GGGGGRRRRRRHHHHHH!
GGGGGRRRRRRHHHHHH!
So recently i posted a thread because my s2000 threw a cel. p0135 which turned out to be primary o2 sensor so i had purchased that and changed in over. No more light. lovely! Its been around a month since the change and now driving home the engine light has come back on. now showing the code of p0138. 02 sensor circuit high voltage bank 1 sensor 2. And a pending code of p0136 o2 sensor circuit bank 1 sensor 2. Am i right in saying this is a code for the secondary sensor now that plugs directly into the cat?
P0137 6 - 3 P0136 ____ Secondary Heated Oxygen Sensor Circuit Low Voltage (Sensor 2)
P0138 6 - 3 P0136 ____ Secondary Heated Oxygen Sensor Circuit High Voltage (Sensor 2)
P0139 6 - 3 P0136 ____ Secondary Heated Oxygen Sensor Slow Response (Sensor 2)
Yes its the one in the cat
ps
I would not rule out compatibility of the Primary you have just installed
pps
According to my recent Mot testing readings, mine is showing slow response times and jumpy readings on the screen <though I fitted a secondary>month ago.
It passed though after a few goes holding it at at 2.5-3k rpm
ps
pps
Mark has Berk HFC
Maybe considering PLX DL6 Gen 4 wideband as better resampling times £156
Maybe you should try refitting your old one and see what happens ?
Originally Posted by dls91
Berk high flow.
I can't explain it proper but it's got something to do with flow of fumes bla bla
Creates an error on ecu
Mine time to time does that and it's always those 2 sensors
Is yours an S2000 or a Volkswagen diesel?
haha well earlier i cleared the error and then decided to do a tct repair again! as it had started to rattle again. after she was silent again took it for a burn and no light has appeared yet so all good!
