handbreak
Old Mar 21, 2008 | 08:22 AM
nashby's Avatar
Default handbreak
I recently changed my rear break pads, cleaned and greased the pistons etc so they r free but i am getting break binding from the rear i think, do i need to adjust hand break?
Old Mar 21, 2008 | 09:25 AM
m1bjr's Avatar
Why, is it broked?
Old Mar 21, 2008 | 10:05 AM
AquilaEagle's Avatar
Administrator
You may have a seized caliper?
Old Mar 21, 2008 | 11:04 AM
nashby's Avatar
well i cleaned the calipers and freed them up, i just wonder if i should have readjusted the handbreak
Old Mar 21, 2008 | 11:05 AM
RUSS H's Avatar
brake !
Russ.
ps did you wind the piston in before you fitted the new pads.
Old Mar 21, 2008 | 11:08 AM
nashby's Avatar
lol i think i would have a problem fitting new pads otherwise
Old Mar 21, 2008 | 12:09 PM
chrispayze's Avatar
Originally Posted by m1bjr,Mar 21 2008, 05:25 PM
Why, is it broked?
Old Mar 21, 2008 | 03:28 PM
MC_BLADE's Avatar
Thw answer is no!, the pisten clicks out on a ratchet. If it did not you would be always adjusting your handbrake.
If your back brakes are catching now, and they was not before you changed them. Then I sugest you did not wind the piston all the way back in.
Old Mar 21, 2008 | 10:32 PM
nashby's Avatar
the other thing is that it only happens when they warm up, its fine when its cold for the first few miles
Old Mar 22, 2008 | 03:08 AM
Itchy Dick's Avatar
How do you adjust the handbrake though? Is it on the calipers, on on the handbrake itself?
