Head Unit Has No Power?
My battery died the other week and after getting it working again the headunit just would not turn on as if it had no power. However a couple days after it just started working again. The battery has been disconnected since and since reconnection the head has had same problem,
Been a couple of days but not back. Anyone got any ideas?
Originally Posted by mugen888,Jan 20 2010, 05:23 PM
check your fuses and check if there is power going to the feed
The fuse should be under the dash, drivers side
You also need to check the Aux socket fuse ( fag lighter) as this is linked to the same circuit as the radio
Might be worth checking how clean the blades on the fuse(s) are.
ThaxOne
04-17-2012 06:38 PM
