Headlight restoration I did today
Old 04-25-2015, 11:32 AM
noirenex's Avatar
Default Headlight restoration I did today
Hi all, thought I would post the before and after pics of restoration of the headlights, they were a bit cloudy and the O/S one was really quite bad, so decided to restore, there are lots of options out there, I decided to try 2 different ones on each light, on the O/S one I used 3M's headlight restoration kit, and on the N/S one I used 2k grit, 3k grit, rubbing compound and glass polish and sealant.
Both came out great, the 3M kit is a LOT faster though, you just have to be careful using the drill so you don't hurt anything, I did it with headlights on the car and just masked off the edges . I only got shots of the 3M kit as below, I used glass sealant and polish on that too (Important otherwise UV will just make it cloudy again in a few weeks)
Tools needed:
Masking tape (I used the blue 3m stuff, it doesn't leave residue and comes off easy)
3M restoration kit
Corded drill set at 1400-1800(ish) RPM, basically so it doesn't catch when sanding
Surface Sealant Glass Sealant UV Inhibitor & Coating
2 x Micro-fibre cloth, one for wiping and wetting when sanding, one for the glass polish application/buff
Water to wet between sands and a spray bottle (Or just use a cloth)
OR
Masking tape
1 sheet of 2k grit
1 sheet of 3k grit
2 x Micro-fibre cloth, same as above
Rubbing compound
1 polishing/buffing pad
Water to wet between sands, and when sanding, and a spray bottle or cloth
IMO the 3M kit has enough to do all 4 headlights if you're careful with the Trizact pad.
Well, before and after:
After:
Nice easy job really and really pleased with the finish!
Edit: I didn't take pics during the job, but one thing to note, it gets quite scary when you are halfway there, scratches all over and frosted appearance makes you think it won't come up shining, but it does, keep pushing through
Old 04-25-2015, 11:36 AM
RobinA3's Avatar
I need to do this - how long did it take with the 3M kit?
Old 04-25-2015, 11:38 AM
noirenex's Avatar
The light was about 15 minutes with the 3M kit, compared to about 40 mins manually doing it with grit/rubbing compound but add on a bit of time for masking off and letting the glass sealant/polish dry (10 mins for both)
Old 04-25-2015, 12:14 PM
DBt85's Avatar
Thanks for this, I'll look into the 3m kit when I do mine!
Old 04-25-2015, 12:39 PM
RobinA3's Avatar
Just ordered a kit :-)
Old 04-25-2015, 12:42 PM
Rich007's Avatar
Looks superb. Was thinking about options for my headlights the other day so this is a really useful thread. Thanks.
Old 04-25-2015, 12:46 PM
noirenex's Avatar
Good luck! I'm sure you'll be chuffed with the result - Don't forget masking tape, I put down 2 layers just to be safe. I also recommend getting a surface sealant & uv inhibitor polish so it doesn't go cloudy again for some time (Depending on if you bought the 3M kit with a UV inhibitor, I didn't)
Happy motoring!
Old 04-25-2015, 11:18 PM
jimmyb1978's Avatar
Cool. Just searched for the 3m kit on Amazon and this was so available
http://www.amazon.co.uk/gp/aw/d/B007...=AC_SY230_QL60
Old 04-26-2015, 03:13 AM
s2konroids's Avatar
Don't forget uv protection.
Old 04-26-2015, 09:36 AM
mikey k's Avatar
which UV protection did you use?
Quick Reply: Headlight restoration I did today
