heated seats button options
I installed the switch in the little triangular panel by your knee, and around the corner from the radio panel. The panel pops out. I installed the kit in 2007, but 10 years later I have to admit I don't use it much - the battery isn't really dimensioned for the additional load.
Originally referenced here https://www.s2ki.com/forums/uk-irela...itted-1070988/ but the photobucket account wont show the images - I always thought this was as clean an installation as you'd ever get, there's not enough room for a rocker switch but these are multiple touch for each heat level.
Didn't know there was an area there that could be used! Interesting what you say... Do you think running these occasionally will cause issues with the battery? Do these put any more load on than an amp or something similar? Is a larger capacity battery a wise choice as a future upgrade?
Left both mine on for a couple of hours without any issues - the alternator can more than cope with the load when the engine is running. You don't want to run them long with it stopped though.
