Help JD Fix his S2000
Hey everyone
Long time no see.
Been ultra busy setting my new life out in Ipswich, so the S has been asleep ready to be awakened in March.
Thing is, she is 15 years old in march and through years of being driven how she was designed she's after some TLC. This is where you guys come in.
Because I new to the area I have no idea who a good Honda specialist is that I trust to work on my car, plus I'm after mainly genuine Honda parts at good prices unless a good upgrade is available. Here are my niggles I need sorting.
Gearbox or wheel bearing noise, needs diagnosing and fixing
Buzzing clutch, need a replacement as it's done 102k now, will consider an upgrade as may supercharge in the future
Alarm doesn't work anymore
Front Discs warped slightly
Timing chain Tensioner starting to
rattle
Tappets inspection for piece of mind
Gearbox plug leaks, most likely threaded, needs oil changing too
New auxiliary belt
Oil and oil Filter change
New Mats
And some new wiper blades lol
All help greatly appreciated
Cheers
Jon
Cheers
Jon
Long time no see.
rattle
New auxiliary belt
New Mats
Cheers
Jon
Cheers
Jon
Have a look on this thread, there is a couple of recommendations, what you are looking at doing is relatively straight forward stuff for any garage to do
https://www.s2ki.com/s2000/topic/106...t-anglia-area/
Thanks Tony,
Has anybody used these guys then?
ROBINSONS MOTOR ENGINEERS LTD
Address Unit 21
Maitland Road
Lion Barn Industrial Estate
Needham Market
Postcode IP6 8NZ
Ipswich
Suffolk
Contact Mr Richard Robinson Proprietor
Telephone 01449 722240
Fax 01449 726015
Wondering what they are like and how much they charge etc.
Thanks Ratty
But Im a bit skint at the minute, if they are still available next month when I get paid Ill gave them off you
Can anybody help with good parts or good upgraded parts? clutch etc?
Cheers
Jon
Address Unit 21
Maitland Road
Needham Market
Postcode IP6 8NZ
Ipswich
Suffolk
Fax 01449 726015
Thanks Ratty
Cheers
Jon
Hello
Gearbox or wheel bearing noise, needs diagnosing and fixing:
Once local trust worth garage has been found this issue can be resolved.
Buzzing clutch, need a replacement as it's done 102k now, will consider an upgrade as may supercharge in the future:
Unless done yourself this can be costly. I replaced mine in April last year and I think I paid 300 quid in Labour + OEM clutch parts from Si at Hendy Performance. Im sure someone on here will recommend a clutch worth upgrading too if you are to supercharge.
Alarm doesn't work anymore: Try replacing the battery, my alarm failed mid last year and I only replaced my battery 2 weeks ago. everything works fine now.
Front Discs warped slightly: replace. brakesinternational.com good deal for cheaper break parts.
Timing chain Tensioner starting to rattle: Either sand blast the worm gear for a temp fix, or buy a new unit. Buy from billman (USA) he dont fail apparently.
Tappets inspection for piece of mind: Have your new found garage do this, unless you can do it yourself!
Gearbox plug leaks, most likely threaded, needs oil changing too: Helicoil, I just use honda oil 10w40 fully synthetic. Others will recommend plenty of other brands. take your pic.
New auxiliary belt: Parts can be sourced from various, easy job I believe.
Oil and oil Filter change: Oil covered previous, filter available from various.
New Mats: S2ktuning have some.
And some new wiper blades: ebay / halfords.
I hope that helps.
Mike
I hope that helps.
Mike
Hello
I hope that helps.
Mike
I hope that helps.
Mike
Thanks so much for the info, I really appreciate it, how much did Si charge you for the clutch kit?
Was your alarm a hamilton palmer which came with the car? Ive never replaced the battery in 6 years of ownership but its never let me down once, the alarm crackles when the batterys 1st connected but thats about it hence why I thinks its the alarm
Thanks again Mike
So can anybody else recommend a good uprated clutch ready for possible supercharging in the future?
Cheers
Jon
Originally Posted by mikefifth' timestamp='1389792035' post='22966052
Hello
I hope that helps.
Mike
I hope that helps.
Mike
Thanks again Mike
Cheers
Jon
No problem only trying to help!
Si charged me £300 to £350 I think. Cant remember off the top of my head. It may have been more. I had my local indie garage do it and they said 400 labour. When I picked it up they were not amused and told me it should have been much more however they stuck to what they quoted - thank god.
I think this may do what you want....but seriously ask around before buying another clutch other than oem as I really dont know. http://www.hendyperformance.co.uk/pr...00_h08023-2100
Well my alarm is standard fitted to an MY01. Its useless. Basically mine wouldnt lock as the alarm just sounded. Error was subsonic alarm trip or ultrasonic alarm something like that. Left me unable to lock the damn thing without it screaming at me. Replaced my battery and the alarm bleeped first time I locked it and now it works fine. Woohoo.
Mike
Cheers Mike, your a legend!
Yeah, I believe you have to drop the subframe to fit the clutch as you can't get to the bolts at the top of the gearbox otherwise, thing is I think it knocks the front geo out so you have to get it aligned as well.
What uprated clutch kit is that? Any lightened flywheels that are good you know of?
Ps the battery swap is a expensive way to check if the alarm is knackered lol
Cheers
Jon
Cheers
Jon
hey j_d
my mate use's richard robinson for his s2 and his other motors and he recommends him, and he is a fussy ole git, i try to do my own s2, as its only a few miles from ipswich pop out and have a chat with him.
we are both in ipswich
Ginger
Ginger
Hi Ginger
Thanks for the recommendation , it's a little daunting moving somewhere new and not knowing a good garage, I used to use Rob at Garage R , but he's 3 hours drive away now .
I can do basic repairs and oil changes my self normally , it's just I don't get the time anymore, and just enjoy driving it now
Cheers
Jon
Cheers
Jon
Cheers
Jon
Cheers
Jon
