Help please Banging Noise
After a lil spin last week I have replaced the passenger side rear alloy, hub, lower wishbone and suspension.
Now when putting it into gear or changing gear I hear a "thud" so I looked under the car and the drive shaft seems to be loose.
Does the drive shaft just sit in the rear diff? or is it held in some how? as the drive shaft legs seem very loose when it sits in the rear diff and has alot of play
Would be great if someone could help me out so I can finally get the car back on the road
Originally Posted by MB,Sep 10 2007, 10:07 PM
Is it the bolts into part 1 which are loose?
Looking at that it might just be nunber 27 I need to hold the driftshaft in the rear diff. does that sounds about right?
