HELP - smell of petrol fumes inside car
For quite a while now I have been aware of the smell of burnt petrol in the, coming in through the air vents. This occurs irrespective of whether air con is on or off, fan-speed and the temperature setting; it is noticeable when the car is stationary, less so on the move. The smell is barely noticeable in the engine bay (with the bonnet up)
So far I have:
- replaced the pollen filter twice
- replaces the oil filler cap and seal twice
- had the valve clearances check and adjusted
- had the air con service and fully recharged
- replaced air intake filter, then installed K&N kit
The car has been fully serviced and MOT'd twice since this issue started, so it cant be anything obvious leaking
What else should I be pointing my dealer towards?
So far I have:
mhhh
No help to you but mine stinks of what can only be described as 'hot fluids' when I have been for a blast. The smell normally comes from the vents.
No signs of fuel / fluid leak?
Have you checked your boot compartment vent is working properly?
https://www.s2ki.com/s2000/topic/465...-trunk-picsfix
Entirely possible for exhaust / engine bay fumes to leak in through that and come through to the cabin via the vents behind the seats.
Failing that ... check the boot / dust covers over / around the gear shifter.
https://www.s2ki.com/...t-trunk-picsfix
i'll check that on the way home tonight - but from memory, I still get some fumes but greatly reduced.....
my boot has, to date, remained resolutely dry, albeit the car really only gets wet when washed (ie no spray is thrown up by the wheels)
