HKS SC kit topic
Old 11-24-2018, 08:35 AM
  #2131
profit_child's Avatar
HKS is a 3 dry layer filter... I tried cleaning it with K&N and it ruined it and effected my boost levels.
Old 12-10-2018, 03:54 AM
  #2132
johnckeen's Avatar
Went for a jolly around silverstone yesterday, car held up great. Gave my friend in a 2015 civic type r run for his money but my rears gave up entering maggets and Becketts ha :P Pulled away down the straights though... Those civics have so much damn grip!
Old 12-18-2018, 01:45 AM
  #2133
johnckeen's Avatar
Can anyone send me their settings in AEM ECU for aircon compensation.
Mine has been repaired now and I need to configure it as it almost stalls when it kicks in.
Thanks
Old 12-19-2018, 02:25 AM
  #2134
Trunkz's Avatar
John it should be in your map file. If you want I can dig mine out and send over and you can compare the values? Obviously dont write my map file to your ECU ;-)
Old 12-19-2018, 05:07 AM
  #2135
johnckeen's Avatar
Just after the value of your please bud, mine was never set so want to know a rough rpm compensation number
Old 12-20-2018, 05:06 AM
  #2136
Trunkz's Avatar
Tell me where its set in AEMTuner and I'll dig it out :-)
Old 02-09-2019, 09:19 AM
  #2137
markforrester99's Avatar
Not sure if anyone has bothered to change the oil on their HKS supercharger yet. I noticed mine was getting abit black and i ordered a bottle from Si ages ago.
Tip for anyone planning on changing it. Drain the fluid out of the reservoir, disconnect both pipes. Put the pipe that comes back from the charger into a waste oil container and then put some low pressure air down the other pipe that leads to the oil filter. I managed to push pretty much all of the oil out using this method. Obviously dont go mad with this method because you could damage the seals in the supercharger but aslong as there is abit of positive pressure it will push the old oil through and out.
Also i wouldn't be too fussed about the charger running dry after a change. I filled up the reservoir to the top and cranked it for a few seconds and it sucked all of the fluid out in no time. As long as you ensure it doesn't run dry i think there is very little chance of damaging the charger while it purges the air out. Mine is now nicely topped up and looking clean. No noticeable change to the charger noise.
It is also worth noting that there is two types of charger fluid and i opted for the stuff suited for warmed climates because the UK is quite mild compared to other places. I cant remember what went in it first time round when i installed the kit.
Si@Hendy Performance (02-09-2019)
Old 02-10-2019, 01:21 AM
  #2138
Old 02-10-2019, 04:04 AM
  #2139
flanders's Avatar
What does the new fluid look like, is it nice and blue like the rotrex one?
Old 02-10-2019, 04:14 AM
  #2140
No its not the same stuff as the rotrex, Its a light brownish colour. Certainly not black like it came out
Quick Reply: HKS SC kit topic
