HKS SC kit topic
Old 11-11-2016, 02:17 AM
  #1091
har-vey's Avatar
Originally Posted by Define198
I would also like to change my 65mm decat for a 70mm one and swap the manifold for the HKS and have it zircotec'd to save even more weight and to try and push for 340+whp. But not sure if the cost of it will be worth it, or if i will even pick up any more HP from these two mods?
Id be interested in the result with a different manifold so keep us updated if you do change anything. The only thing that puts me off changing the exhaust manifold is the sound. Aftermarket items tend to be so much thinner than OEM so you get a tappy noise from them.
Old 11-11-2016, 02:33 AM
  #1092
Trunkz's Avatar
I've got a J's manifold on mine - will also have a Skunk2 throttle body for maximum cushion pushing action..
Old 11-11-2016, 02:36 AM
  #1093
Define198's Avatar
Oh nice! will be very interested to see your results with the manifold, does the throttle body make much of a difference?
Old 11-11-2016, 02:57 AM
  #1094
Trunkz's Avatar
Supposedly squeezes out a good few ponies. Not sure if I need to port the inlet manifold to maximise this.. but we shall see
Old 11-11-2016, 03:12 AM
  #1095
UK Trader
Si@Hendy Performance's Avatar
I have one HKS Manifold in stock - brought in before the price rise Can do you all a deal on it!! (we use it on display rack for shows). Still have the box etc
£820 delivered
Price now:-
SS Manifold S2000 twist 33002-AH001
Old 11-11-2016, 03:22 AM
  #1096
CynicG's Avatar
I have ordered the J's racing front bumper which is due February...
I'd be really interested if you could gauge the actual impact to cooling from this bumper (assuming it's v2). I'm thinking about one as the car starts cooking after 15-20 mins on track. If it can achieve 10% extra cooling efficiency then I'm in. Some before and after metrics would be fantastic.
Old 11-11-2016, 03:50 AM
  #1097
Define198's Avatar
£820 delivered
Price now:-
Hi si, i thought i remembered you said you had one a while back, after just buying the J's bumper i need to recover, and most of the work i have planned is going to be after the new year march/april time to get the car up to spec for next summer, will also be buying the coolant sensor and water pump from you after new year so if you still have the manifold by then i will hit you up
Old 11-11-2016, 03:55 AM
  #1098
Define198's Avatar
Yep its the v2. Wont have any concrete info as i will be doing everything at once - delete aircon, new coolant sensor, new water pump and oil cooler - so i am sure l notice a big difference but how much the bumper alone will have i doubt i will know. the hole to feed the air filter direct i assume will make a positive impact.
Old 11-11-2016, 04:19 AM
  #1099
CynicG's Avatar
No worries. I don't doubt the increased mouth will have a positive impact on cooling (not sure the air direct to the filter will make that much difference if going to the inter cooler anyway but it can only help I suppose)
Old 11-11-2016, 04:54 AM
  #1100
johnckeen's Avatar
I don't believe it, my neighbour has just reversed into my car pushing wing in, bumper down and headlight out, are you ****ing kidding me!!!
Quick Reply: HKS SC kit topic
