HKS SC kit topic
Old 01-05-2017, 01:01 AM
  #1341
Mr-T's Avatar
My belt seems to slip sometimes at top end, but have a little adjustment left. Might get a conti belt and replace it anyway and keep the HKS as an emergency spare.
Old 01-05-2017, 01:34 AM
  #1342
markforrester99's Avatar
Im sure this happened to me the other day but it was about -2c outside. I wondered if the supercharger oil gets quite thick and struggles to get things going first thing in the morning. After about 5 seconds or so the noise stopped. The supercharger oil cooler seems to warm up quite quickly once the car is running thou.
Old 01-05-2017, 01:41 AM
  #1343
Mr-T's Avatar
What catch can's are people running? Just the cheap Fleabay £20 ones, or anything a bit more specific?
Seen a baffled one for around £40 that doesn't look to bad.
Old 01-05-2017, 02:03 AM
  #1344
johnckeen's Avatar
yeh it went away after about 5 to 10 seconds, might just buy a conti anyway... cant hurt
Old 01-05-2017, 02:04 AM
  #1345
johnckeen's Avatar
Might just do the plastic bottle hack and see if it really is pushing out a lot of oil before i go buying a catch can.
Old 01-05-2017, 11:56 AM
  #1346
E4RTH WORM JIM's Avatar
You want a catch can (or dual) vented to atmosphere
Old 01-05-2017, 12:02 PM
  #1347
Originally Posted by markforrester99
Yes mate had to do a couple of things
- Refit the turbosmart BOV the opposite way round so it acts as a vacuum operated bypass similar to how the Audi/VW bypass valve works
- Adjust one setting on the AEM ECU under O2 feedback. It was set to stop fueling at TPS less than 2% but as it jumps around between 1.5-2.5% the engine was injecting fuel even thou the throttle was fully closed. Adjusting that to 3.5% sorted that.
- Dismantled Throttle body and added O-ring on TPS end of shaft, Lots of red rubber grease on all the parts to try and stop any water meth getting through to the TPS
- Spray at 5PSI onwards
I'm a couple of clicks away from getting one. I've looked at all sorts of options to lower my AI Temps but this seems the easiest and quickest option.
Thought I needed a SOS TB as they use nitrile orings, I'm glad there is a cheap DIY on the OEM TB
Old 01-05-2017, 11:28 PM
  #1348
UK Trader
Si@Hendy Performance's Avatar
We have a few options of Oil Catch Can on the shelf
Linky here:- Universal
Old 01-06-2017, 01:29 AM
  #1349
johnckeen's Avatar
Out of all the ones on your site Si, which would you recommend?
Old 01-06-2017, 03:27 AM
  #1350
UK Trader
The rockstar one has proved popular! Although its the same as the one below - the 3 port one is the top selling one! The current discount code(s) should still be live.
Rockstar Compact Baffled Oil Catch Can 2-Port Black
Mishimoto Compact Baffled Oil Catch Can 3-Port
The drain kit makes life easier :-
Quick Reply: HKS SC kit topic
