HKS SC kit topic
#1491
For flames on over run you only need to retard ignition timing on over run and it will pop and bang all day long. There will be enough residual fuel from a full throttle run to still pop flames out the back. I have no fuel on over run and it chucks huge flames out
#1492
Did you ever sort it unlocking your map? If you have a wideband sensor you really should be using O2 feedback. Otherwise you car can make very little adjustment based on weather conditions. You might as well start throwing money out of the window. I don't mind helping you out just send me a PM
as far as i am aware 02 feedback is enabled.
#1493
tial qr BOV just arrived to hopefully get rid of the flutter. So just waiting on the adapter plate so i can fit it to the car, and then i think i need to sort out some new hose and adapter so i can get it to re-circulate.
Really impressed with turbodynamics, they even stripped another bov to get me a 2psi spring as they didn't have any in stock!
#1494
Yeah, did the same for myself and Har-vey. Good guys. Guy is probably wondering why he is suddenly selling loads of 2psi BOV's.
If you want to re-circ, then easiest is probably just a reducer from the BOV into your existing pipes, unless you want to replace all hoses with silicone.
Will try and get a picture of my setup tonight. No re-circ though.
#1496
I think mine and Mr T;s were actually springs they had on the shelf, not swapped out from another BOW as with Define198. It was nice of them to fit the spring though to save us having to buy it as an additional spring as they sell for over £20 each
